It is currently Thu Aug 14, 2025 10:19 pm
 Post subject: Some Archtop stuff
PostPosted: Fri Feb 13, 2015 4:36 pm
I am working on an archtop neck and thought I'd show a few jigs I use that have worked for me. I'd be interested in how some of you other archtop builders approach the same issues.
Here's a multipurpose jig that serves as a router guide to rout the ledge for the extension and as a clamping jig as well. Keys in the truss rod slot.
Also holds the extension in place and allows clamping in all planes during glue up. The extension piece has to be thickness sanded to exactly the same thickness as the ledge cut.
Here is a jig for routing the continuation of the reinforcing bar slots. Keys in the existing slots. Same principle for the extension of the truss rod slot.
Rubber tubing works well for pulling the neck bolts into their holes. I usually put a rubber washer on the inside to retain them.
 Post subject: Re: Some Archtop stuff
PostPosted: Fri Feb 13, 2015 4:50 pm
That's clever with the rubber tubing but how in the world do you get a wrench in there? I use a bolt on for Selmer guitars and have a cool little flexi shaft tool but I can't imagine using it through an F-hole. Do you have a back or side panel or something?
PostPosted: Fri Feb 13, 2015 5:10 pm
i
You have to drill your Jack hole and use a long Allen wrench through it. I just epoxied a ball end Allen wrench to a length of threaded rod and put a handle at the other end.
These users thanked the author Terence Kennedy for the post: jfmckenna (Mon Feb 16, 2015 1:22 pm)
PostPosted: Sat Feb 14, 2015 2:05 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Nice stuff, Terence. I've been dovetailing my neck extensions on, but it appears your routing jig would work for dovetail necks as well as bolt on necks.
PostPosted: Sun Feb 15, 2015 2:02 pm
Last Name: Beaver
City: Lake Forest
Some very clever stuff here !!!
Joe Beaver
Maker of Sawdust
PostPosted: Fri Feb 20, 2015 10:19 pm
Very timely.
Old growth, shmold growth!
PostPosted: Sat Feb 21, 2015 3:57 pm
First name: George
City: Seattle
I love archtops and yours are consistently gorgeous, Terence. Awesome jigs, too!
George :-)
These users thanked the author George L for the post: Terence Kennedy (Sat Feb 21, 2015 7:16 pm)
